addressing the last 2 posts, it was a Pep Boys reman short block bought 7/99, but car mileage unknown at that time. When the car was sold in '03, it had 116k on the odo. per bill of sale, and currently shows 117k and change. I bought it from guy who had it approx 10 yrs, who got it from a bro-in-law. Pep boys docs show CID at 4.050" x 3.780", and “352” appears where it should, so no question it’s a stnd bore and stroke 390. above the “352” there’s a “59,” and i thought i saw a “DIF 41” where the date casting should be, but i may re-check that. the owner at that time had the foresight to remove the little engine ID tag, which shows 390 built 12/66 and 67 model yr.
other receipts support motor work in summer of '99, including fuel and oil pumps and overhaul kit from Summit, and a machine shop inv. for surfacing and drilling of “Ford 390 Head GT.” The fp still looks new, and the PO seemed to suggest it was, but if it’s the same as per the receipt, it’s 15 yrs old, but has seen little mileage. PO said car was garaged whole time and only driven to preserve tires, fluid, etc., and i don’t doubt it, since he lived near the desert and the interior woulda been toast if left outdoors, and the tires are not out of round or cracked, and the receipt shows they were bought in '02. Full 3" duals were '02.
regarding the heads, “fomoco” is present pass side back, and PO said they were “special.” i hadn’t intended to pop a VCover, but now i’m curious and may do that. the fronts are bare, and there’s no room to check the backs.
PO provided old PO pics showing engine bay and heads, but i can’t id them from that, 'cept to say the rocker arms appear stock. these pics clearly show an intact AC system, but PO said he got car w/o that stuff.
i thought ford didn’t put VINs on drivetrain till '68, but if there’s one on the trans i’ll look for it.
my own hunch is that the clutch inexplicably wasn’t done when the motor was, and when it showed signs of wear, PO drove it less and less, to the point of not registering it for 2 yrs. the test drive was short b/c it wasn’t registered, and he mashed it in 1st and it went like a BOOH and filled the cabin with rubber smoke, and nothing seemed odd when he grabbed 2nd just as aggressively. since the rest of the car checked out, I didn’t press for more of a mechanical shakedown/test drive.
I’ll shoot a vid of a little drive, but don’t really want to get too aggressive given the clutch.
prolly more than you asked for, but hope this helps…
…BTW i realize that many of you are not near CA, but i have done long distance car deals in the past, both as buyer and seller, and can provide references as to transactional trustworthiness.
