It appears I have no power to the relays for the seat belt indicator, fuel level, parking brake light, door ajar switches. By looking at the diagram there appears to be an inline fuse. I am having a difficult time finding it. Can anyone point me in the right direction? Thank you in advance.
The inline fuse will be in the #365 Blue / red stripe wire that plugs into the three receptacle yellow plug. It is located in the wiring harness just forward of the ignition switch. Wire 365 should have a white rubber band around the connector.
Thank you very much, I know where the 3 prong yellow plug is. There is only one thing (I think the blower motor power plugged in) I will try to search out the blue/red stripe wire.
This seems to be the only blue/red stripe wire I see. It had a red female connector . I am guessing this is not the correct wire?
Not sure what that is but it’s the wrong wire and totally wrong location.
