69 Cougar upper rear shock mount
Hi everyone I’m looking for some help with mounting the rear shock upper brace i’m sure that’s not what it’s called. I’m wondering if anyone has any pictures of where the screws or bolts go on the rear shock mounting brace in the hump. Mine has a bunch of holes for what looks like sheet metal screws and two or three nuts and bolts.
Any pictures of this BRACKETT and how it’s mounted under the hump for mounting the shocks where the screws or nuts and bolts go I would appreciate it
I’m also not sure where it is welded I can see it welds on the frame but there are a bunch holes on top side of the hump on the inside behind the seat and along the top of the hump.
The upper rear shock mount is basically just a 1" hole through the hump forward of the axle. Shock mounts with rubber bushings on top and underneath.
Hi Calicat I didn’t explain myself good enough I removed the bracket that you bolt the shocks too. My problem I don’t believe it was install properly it had a few sheet metal screws and some small screws and a few nuts and bolts on the shock bracket.. I see were it was welded on the ends of the bracket to the frame. I’m not sure that it has enough screws or are there bolts or is it supposed to be welded in place?
Anyone with any pictures would help there are a lot of holes along were the bracket for mounting the shocks to the thin steel in the hump brace is do I weld it our put screws in it or bolts and nuts?
I really appreciate any information you can give me on this I wanna make sure that I put it up there right and secure. It did have what I would say was one reference bolt in the bottom front of the bracket….
Thanks for any help here
Fred
That bracket is welded in at the factory mostly useing spot wekds. I don’t think the stressed it takes will hold of bolted and sheet metal screws are how it gets reinstalled. It could be temporally held in place with sheet metal screws while it gets welded in.
Can you do the welding? If not, you might find a modal welded that may be willing to weld it in.
Hi badcatt so the bracket is welded in that’s kinda what I thought… who ever put it in there were a few welds but mostly screws and a few bolts. I didn’t want to weld it all in if that was not right. But yes I can weld it in no problem I’m not the best welder but I can certainly weld that.
Ok so just screws to hold in place and spot weld it in all the way around, there are a few tabs inside that bracket I’ll just stick weld so I can get to them and mig weld the rest of the bracket in.
I really appreciate the help with this I’ll be out in the shop welding that in today it will be tight when I get done. You guys are a wealth of knowledge on this car. Torq box’s and floor pan’ have been replaced.rear end is cleaned up and almost ready for paint. I need to find a posi for the 9” rear end I don’t know how many splines the axles are it a 69 M Code 351W 4V
Thanks badcatt
Fred
Thanks for your help @badcatt here are a couple of pictures I took today. I have a little more to do to clean it up a bit more but for all practical purposes, it is welded in. Thanks again for your help. This is a work in progress I still have quite a bit to do.
V
Fred1 great information for those of us just beginning the this journey. Personal I’m finishing up some projects then full speed ahead :grinning_face:
Ford did spot weldsabout every 2 to 2.5 inches along where it meets the floorboard. Then stich welds on the frame rails, If that is what you did great. I just can’t tell in the pictures. Just the same, great progress.
@badcatt Thanks for keeping me heading in the right direction. So I did spot welds along the inside of the car along the bottom and the top of were the shock mount brace is. But I have not stitch welded along the frame rail under the car. I’m glad you said something about that because there is no way to get to the factory tabs inside the shock mount bracket I can get to the drivers side if I stick weld it but it would be much Easier to stitch weld along the frame rails under the car along the frame rail on each side.
Inside the car I sanded the welds to smooth them out there were a lot of holes were someone had put screws in that ripped the metal because it wasn’t strong enough. I was looking at the bracket under the car and wasn’t sure if I should stitch welding along the frame rail or not. I was thinking it would be a good idea to tighten that up. Thank you for looking at where I welded, I will stitch weld along the frame rail under the car.I put a picture of before I sanded the welds down inside the car. I appreciate you pointing things out for me. Thanks @badcatt
