Added an audio input to my 68
This was a relatively easy mod that took less than a full afternoon and $5.00 parts from Radio Shack. Keep in mind that my experience/knowledge of electronics goes little beyond understanding that it is bad to let the smoke out. My goal was to maintain a factory look with the radio but have the option to plug in my iphone for some tunes. I had been using an rf modulator to do this but got sick of the crappy sound so I figured I’d open up my radio and see what I could do. The first thing I thought was necessary was to figure out a way to kill the signal from the FM tuner so I could introduce my iphone’s signal without interference from the tuner. My radio is one of those mid-70’s AM/FM standard Ford radios with the slider below the pushbuttons for left/right balance and I figured that was a logical place to start. Sure enough, following the traces from the slider switch on the pc board led me to some leads on the volume/tone pots, where I was able to add my left and right signals. I confess I found the exact points to solder in the left and right inputs by randomly poking around in that area until I found spots that gave me a clear sound from the correct speaker outputs. From there, it was just a matter of running wires from those points out to a 3.5 mm stereo input jack. To give me the option of temporarily killing the radio signal when using my iphone, I simply scratched a break in the traces on the pc board leading from the balance slider switch (since I figure both left and right channels had to go through there at some point). I then soldered in wires leading to a toggle switch allowing me to connect/disconnect those traces at will. As you can see from the pics, I was able to fit both the switch and the input jack in the ashtray next to the lighter socket so as to be hidden from view when not in use.
I’m happy to report it works great. I’ve since discovered that my toggle switch to interrupt the tuner was unnecessary. Simply sliding the AM/FM selector to AM accomplishes the same thing.
this is really cool. I was thinking of a similar thing but had no idea where to start, now i do! Thanks
Jody that is a neat mod. I wondered if doing something like that was possible. I still use my factory am/fm but it would be good to be able to have an ipod jack for extra tunes.
I have since discovered that the tone and fader controls don’t work with the iphone plugged in, which I suspect means that I injected the new left/right signals in the wrong place, but I’m too lazy to tear it all apart again to fix that. That’s not a huge deal since the iphone has its own EQ settings. I just thought I’d pass that along if anyone here wants to try this. I should also note that my input is most likely not the equivalent of a standard “line input” (at least I don’t think it is) since the line input adapter for my iphone actually sounds worse than the signal from the headphone jack (which sounds perfectly clear). So whether or not I could run another device, say a CD changer, into my radio through this is an unknown.
I
