Looking for an OEM air cleaner housing for a 1971 XR7 351 4 BBL
So
Really not sure if they are the same
but I have one off my original 1970 XR7 351C 4v
I may part with
Thanx!
Let me check if that is the same one, if so I would be interested. How much?
Well
Is it the correct one?
Someone painted it black years ago other then that it’s in good shape. Will need to be repainted.
I can send pics if you need them!
Here is a possible answer ( I hope ) to your questions.
According to the MPC the part numbers are different for the 1969 Windsor and Cleveland ( engine ) air cleaner assembly.
The 1971 part number ( for all 351 engines ) is different, again.
The only thing in common between the 1970 and 1971 air cleaners is for the 2 Barrel Windsor air cleaner dimensions and the dimensions for the 1971 351’s. So maybe a ‘trial’ fit of a 1970 Windsor air cleaner onto a 1971 351 V-8 might definitively answer
the question - maybe ( with any degree of luck ) any ‘fitment’ issue has to do with the snorkel portion of the air cleaner ?
Or maybe it has to do with the profile on the bottom of the air cleaner base, where is sits atop the carburetor ?
Here are the air cleaners “by the numbers” :
(1) 1970 351C p/n is D0ZZ-9600-M. 17.00" diameter and 4.20" high. ( Notes ‘a’ and ‘d’ from the MPC )
(2) 1970 351W p/n is D0OZ-9600-B. 17.84" diameter and 4.20" high. ( Notes ‘a’ , ‘d’ , ‘m’ and ‘n’ from the MPC )
(3) 1971 351 V-8 ( all ) p/n is D1AZ-9600-F. 17.84" diameter and 4.20" high ( Notes ‘a’ , ‘d’ and ‘r’ from the MPC )
Here’s the MPC ‘notes’ :
‘a’ = wing nut 1/4"-20 ( air cleaner to carb ) 358871-S ( MM297A )
‘d’ = stud 1/4"-20 X 5/16"-18 X 3 13/16" ( air cleaner to carb ) 370971-S ( WW100 )
‘m’ = elbow [ use in air cleaner to connect hose ( 6853 ) ] p/n : C8AZ-6767-A
‘n’ = grommet [ use in air cleaner to retain elbow ( 6767 ) ] p/n : C8AZ-6A892-A
‘r’ = elbow 5/8" X 3/4" - 90°. Nylon - crankcase vent 384411-S ( II-187 CF )
All the hardware numbers and FoMoCo p/n’s ( in the MPC notes ) still show as available with a
Google search, as Reproduction or still available as Ford OEM.
Good luck with the ‘hybridization’ of your air cleaner assembly !
No 351C for 1969
(2) 1969 351W p/n is D0OZ-9600-B. 17.84" diameter and 4.20" high. ( Notes ‘a’ , ‘d’ , ‘m’ and ‘n’ from the MPC )
Note the 1970 part number, S/B 1969/70 replacement for 1969.
The 70 and 71 Cleveland air cleaner base and lid ae the same. The snorkel is not the same. And out side of the sticker they are the same for a 2V or a 4V. It should not be to hard to find the correct parts for one for your Cougar. I have a 70/71 base and lid but no snorkel.
My error. I have a 1969 Cougar XR-7 and am so fixated on it ( who isn’t ) that I accidentally typed in 1969 for both the 1970 351C and the 1970 351 -2/B ( W ). I have corrected my post. All the other numbers and data is correct, at least according to the MPC !
For what it’s worth, the 1969 351 (W) air cleaner assembly has a 17.84" diameter X 4.20" high and has part number C8AZ-9600-D.
Been there done that and did it on my last post.
The size is the same between 1969 and 70, but the breather elbow is swaged on metal on the 69 unit and is a plastic one held on with the grommet on the 70/71+
Nothing like a good senior moment now and then.
I hope your July 4th is going well.
So,
Mine is complete with top, bottom and snorkel
It’s the only thing I have left from my 1970 XR7 Cougar I bought in 1986. Just recently sold the drive train from it, body went years ago
Actually wish very much I had it back, It was equipped with a factory sun/moon roof. Not sure how many were available that year but I assume not many.
Have no Idea what the assembly is worth, any one have an idea please share
Thanx!
Joe
