got the Brake Distribution Switch Tool but I don’t know the the order in which to do it
do I simply remove the existing sensor and screw in theBrake Distribution Switch Tool the pump then pump the pedal and bleed one by one?
Remove the Brake Warning switch from the distribution block and install the tool. Don’t over tighten the tool because it applies pressure on the internal shuttle valve and over tightening will bend the valve. The tool just holds the shuttle valve in place while bleeding the brakes. When done bleeding the brake system, remove the tool and reinstall the Brake Warning switch. It is that simple.
Great thank you
