Reviving the DragCat after the ruff n tumble Mangy Drag Cat swallowed a valve pulling away from a Rat…lol
The iron headed 408 is out
393 Scat Stroker with AFD SP4V aluminum heads is in…no more hyd roller …this one has a “BullettCams” solid flat tappet with 268/275 @ 050 with 680 lift. After getting it fired up and run above 2K for 20 mins…got some adjustments made. Turns out the locked distributor needed to be dialed down to 25 degrees advance for it to spin up…thats down from 36 for the Iron CC heads …fast burn chambers in deed !, See attached link for some " ear candy"
https://youtu.be/Fs_GfCSLQrY
