Flexplate signs
Howdy, has anyone experienced early to late symptoms of a failing flexplate on FMX?
If face is cracked, will vibrate, make noise or both.
If ring gear fails, will grind or skip when starter engages.
If wrong imbalance (weight), engine will vibrate.
Remove the inspection cover, manually rotate the engine, and visually inspect.
Think fmx has a drain plug line up to the flex plate that can cause some issues
