Hood, trunk, and interior parts.
Just went through some parts of the new project and I have the following available. Located near Vancouver, Canada close to Washington State boarder.
-Grade A hood for sale. It is really nice with no signs of rust starting under the lip at all.
  • Grade B trunk lid with some slight rust starting under the lip but very repairable and even has the cougar script on it.
  • Ivy Gold door panels, rear panels, and rear seat available
Let me know if interested in anything.
You will want to add the year and a few other details, (STD or XR7) to get these parts sold. It is a good idea to add information about your car in you signature, and also your location to your profile. It gives people a bit more to work with when they respond.
Well I did say near Vancouver Canada close to Washington state boarder if you are near enough you will know exactly where I am. The hood and trunk lid need no explanation of model and I did post under 67/68 which should explain years. Interior is Deluxe from a 67 standard Cougar, not XR7. I will supply pictures as per request as they are in storage not near me at the moment.
I am trying to help you. There are a lot of differences between '67 and '68 in interior parts. Among other things, in '68 there were two levels of standard trim, (decor and base) the base level did not include rear arm rests. Ivy gold is a gold-ish green color for standards, and called dark Ivy gold for the XR7, a very dark green color.
In general, putting the details in your signature helps people understand what you are working with. For example, if you want to know what jets to use in a carb, the thing that every one needs to know is your elevation. In mountainous areas, it is a lot different from one location to another. I live in the phoenix valley area of AZ, at about 1800’ but just an hour away in Payson, the elevation can run to about 7300’ elevation.
When people list the details of their cars in the signature area it also helps other people who are working on something similar. I get a lot of questions about sunroofs, tilt away and cruise (speed) control, that I can answer because I have those things listed.
Of course you don’t have to do any of those things, I just wanted to let you know why I was suggesting them.
price is also good thing to add
