Looking to install new clutch
I need a new clutch for my 351C Eliminator. I want to make sure these are the correct kits. Are the clutches 11 inch? Looking at two clutch kits from Rock Auto do I want lever action or diaphragm? And if I were to change to the diaphragm Style is it a dirrect replacement? Thanks
The 3 finger pressure plate is more of a performance style having significantly higher spring force when the clutch is engaged. Downside is you’ll need to apply more force to disengage too.
The diaphragm style is just fine for most applications and is much easier on the leg in traffic.
The Long style clutch is the way Ford delivered the car. Many folks go to the generic motors style diaphragm clutch due to ignorance. Often the clutch linkage is shot adding to the difficulty. Replacement kits are available.
The diaphragm style clutches were standard on fox body mustangs as well. The clamping pressure can be significant and the release pressure is lighter allowing the stock linkage to live. I highly recommend installing the roller conversion for under the dash. You’ll also need to remove the over center spring due to the light release pressure. I’ve installed several of the diaphragm set ups in fe big blocks, 429, and small blocks to help my aging dad out with lower pedal pressure. Never on a 351c, but I can’t imagine it being much different. Do not convert to a roller pilot bearing with a stock 4 speed as the hardened roller will destroy the input shaft
Let us know if the diaphragm style clutch bolts up to your OEM flywheel. Seems like they have a different bolt pattern?
Wow I would say so thanks for seeing that! Not going to work.
