Rear valance modifications on my 68 XR-7 to pull it tighter to the rear quarter. The Bezels I made out of a sheet of 1/4” Aluminum
Fyi… I did a similar mod in 2007/2008 on our 67 big block gt . Muffler guy did a great job keeping the pipes up in the tunnel and nothing hanging down BUT fuel tank temp got to 45 deg over ambient temp…I saw 155 deg with my heat gun !!
Ended up wrapping the sides of the tank with thermo tec adhesive foil flexable sheet and using thermo tec heat shield and standoff on the pipes going by the tank. Got the tank temp back to ambient and no more bubbling sound coming from the tank!
Not sure if it was the proximity of the pipes to the tank or the fact that putting the pipes up behind the valance reduced the airflow or both . But just keep a eye if making this mod. Sure looks good tho.
Thank you for the advice and I really appreciate it. I will definitely check the temperature of the fuel tank once I get it back on the road.
I still need to cut the tailpipes and put the chrome extension on after I get it painted. I also had to make a transmission cross member for my T5 transmission so that the pipes were able to get pushed up tight.
Thanks again for the help ![]()
Can you describe a bit more about how you make those curved bezels near the exhaust tips?
I bought a 1/4” Aluminum plate from Amazon and laid it out on the plate. Then I used a hole saw to cut out the middle and then finished cutting out the rest of it with a jigsaw with a blade made for cutting aluminum. I also used a sanding drum on my drill press to smooth the saw marks out of the pieces. Left them a little long so that I could hammer and dolly the ends to match the round of the bottom of the valance. Sanded them with different grades of sand paper rounding the edges while sanding and then buffed them out. Drilled and taped the back for 3/16” screws. Cost me like $25.00 bucks to make.
Looks great! I modified my rear valance as well. I used exhaust cutouts from a 70 Mach 1 and used the Mach1 tips as well. Drdesoto has me a bit worried now. I will have to check that once I get the car running again. Couldn’t find my Cougar pics but this is from my Mach1, the original inspiration
Mike those cut outs and exhaust tips looks Amazing! You do nice work ![]()
Well that’s actually the factory panel on my 70 Mach1, the inspiration for change. This is the Cougar valance:
These look clean!
