Well, its been a great season and near 80 degree day in Western NY…took a cruise. But things started to unravel. I heard something drop from the bottom of the car…nothing too big but definitely something. Pulled over, looked underneath, kicked the tires and decided to try and make it home…about 10 miles. An unsettling grind from front passenger side tire, maybe wheel bearing I thought but a very unsettling situation evolved, intermittent grind with odd oscillation…had to crawl at about 5mph…almost made it…too vague to postulate…whatever it is, it does not seem good…to be continued
I know how THAT feels. Hagerty insurance. I’ve towed Greeny 5 times. Yet to pay a red cent!!!
That grind changing pitch and coming and going at low speed sounds like it could be a bearing or a brake caliper dragging rather than something loose in the driveline. Good call limping home slowly instead of pushing it. Did you get a chance to jack up that front corner and check for play or heat at the hub? Curious what the dropped piece turns out to be — that detail may narrow it down fast. Hope the tow bill stays manageable and the diagnosis is simple.
No heat in hub, noise would not change with brake application. Front u joint has play but very little. Getting to it in earnest this week. My guess is cracked flexplate…
