I HAVE A FEW FRIENDS THAT HAVE A 67/68 COUGAR and have done a swap to a 351 Windsor motor. I recently got a wild hair and bought a 1970 351 motor and plan to rebuild it to put in the car. I have been told everything will swap over easy! The more I look into and purchasing parts I’m finding differences. My 301 has some headers and not sure of the brand but because of the height and width difference, I’m hearing it may or may not work and cast manifolds may be the only option? Also, the accessory brackets may need changed or reworked. I have classic air, power steering on my car. The alternator does not worry me. Also, the water pump! Ford has a right and left side discharge! I think I found out the new water pumps are 289/302/and 351 clockwise rotation and will be fine on that. 68 has a passenger side and 69 or 70 they change to driver’s side. Any advice would be appreciated! I may decide to keep a 302 if it’s too much issues!
My 2 cents… Standard exhaust manifolds. Headers are EVIL!!! And they REALLY don’t make that of a difference. These aren’t race cars.
The change was after 1969. The water pump discharge is the same for a 68 and a 69. I would recommend you get a 1969 balancer that uses a 3 bolt mounting for the crank Pulley. You can then use your existing pulleys. Then get the 1969 351 alternator and power steering adaptors.
and
You will need to find out if this will be needed with your aftermarket A/C or id you will need something else to align up.
Using these parts your 302 accessory brackets and pulleys should work well.
Good luck with the swap.
Have a 69 351w in my 68. Couple suggestions if you have power steering use big block ps hoses. I’ve been running Tri y headers for 8 years with no issues or leaks. Went with ceramic coated and they still look good. Installed easily. Good luck with your swap.
I’ve done the swap several times and it isn’t that hard. Headers will work if they clear the C4 transmission or the top loader. The mounts all bolt up no problem. The big problem is the PS mount, it is 351W specific.
I had a set of Hooker headers on my 302, but they wouldn’t work with the 351W. They interfered with the steering gear box and maybe the frame on the driver’s side. I started to bash them, but it quickly became clear that it would take way too much to make them fit. I ended up going with Heddman mid-length “swap” headers. They fit nicely, but a couple of the bolts on the rear driver’s side are nearly impossible to get to.
I used the 3-bolt balancer and the bracket adapters mentioned above and was able to use my stock PS pump and alternator, no problem.
One thing I learned during the swap, don’t expect to use your 302 distributor in the 351. They’re different, I think due to the taller deck height of the 351. The taller distributor also conflicted with my 14" air cleaner, so I had to find a smaller solution.
Like the artwork
He scares away the garage gremlins ![]()
I need 1!!!
