May the force be with you on that! Sounds like th did it by the book which I am not too good at doing.
I did the sealant on the housing, gasket on, sealant on top, then stuck it in the manifold. Wonder if that order really makes a diff.
Thanks for sharing Steve, love your car.
Must be seeping through the bottom while driving to/from the office. The gasket I used was from NAPA and had adhesive on one side (like a sticker). I put the sticky side toward the manifold and smeared the housing side with a thin coat of Permatex. I’m going to try just straight Permatex- no gasket- this time.
I did see that some have done that. I will be interested in what Permatex you use and if it works. Seems like the cheap gaskets are just a paper product, not much of a sealer. Yea, a slow leak there probably can evaporate fairly quickly and just drain the coolant over time. Did you see a little puddle underneath on top of the manifold? Let me know how it goes.
Mine hasn’t been tested yet with the engine running.
FWI update: I never did get around to re-installing the thermostat housing on my J code, but I think I have eliminated the slow leak/seepage issue by switching from a 13psi radiator cap to a 9psi cap. I know that the new cap lowers the boiling point of the coolant a bit, but my cat never runs all that hot anyway.
