I plan to check for cylinder pressure soon, I’ve been out of commission for a little due to a surgery but I should be getting back to it, and now that I’ve dug up my pressure gauge I’ll know soon. I had the engine built by a shop near me, if I remember correctly they installed it straight up, although I’ll have to check the paperwork from them.
As for vacuum, it’s been a while since I ran the gauge somewhere where I could read it while driving, but last I remember I had about 11" of vacuum in 1st, under light load, and then as soon as it would shift, it would nosedive to less than 5", if I let off the throttle it’ll jump right back up to 14" or so.
I’ve swapped power valves around, I believe it comes with a 6.5, and I tried both a higher number, 8.5 I think, and a lower, 4.5, and neither seemed to really change much. I did some reading around and came to the conclusion that if you can get above a certain threshold with idle vacuum than the power valve number was less critical, much of what I read seemed to indicate it was much more crucial on engines with a more radical setup, but I’m open to any changes now really.
I’ve tried a lot of different timing setups, none have seemed to fix the problem, I’ve noticed changes and small improvements or deteriorations, which led me to believe it was the carb causing the big problem, but so far I’ve gone all mechanical and it seemed to have improved.
And lastly yes, that valley pan was toast, I’ve never seen something like that happen to something that has no water running through or over it, but from what I read the high heat, low oxygen environment inbetween the pan and intake seemed to have really done a number to the oil that got trapped there.
