Hi all!
The boy and I replaced the Vacuum Actuator Seals (Thanks again Don!) and now we want to tackle the leak in the Vacuum Tank (the one in the driver’s side wheel well).
Ours has the TWO inputs.
Is there a “Fix a Flat” type of spray that can be used to repair these? How does one go about doing this?
If they leak it is generally because they are rusted out along the seam. There’s no good repair for that. The good news is WCCC sells used ones for a very affordable price.
Thanks man. Surely there’s a repair kit? A fix?
I don’t mind replacing the tank…but I mean… it seems like it’d be a simple thing. Maybe JB Weld or something?
How do you track down the leak?
Hello ssava, I am converting to electric actuators. You can have mine for free if you pay shipping. Send me a check when you receive it. Shoot me a PM if you are interested. Jim R.
Hey, you can not beat free, but if you just want to find the leak for the heck of it, submerge tank in water and add air to inlet on tank and watch for bubbles.
Edit–looks like I took to long to type
Thank you all! And thank you 19cougar68 for the amazing offer.
My son really wants to give fixing it a try as that’s kind of the reason why we got her. But if we can’t… we will DEFINITELY take you up on the offer.
So generous.
We will take the tank out and submerge it and see.
Keep in mind that this is a vacuum tank, it holds negative pressure if you want to think of it that way. So it will pull any coating on the outside in.
Dunk the tank to find the leak and see how bad it is, if it’s rusted don’t mess with it just replace it. If it’s just a pin hole you can just patch it up by either welding or using an epoxy like jb weld.
Of course, we’d LOVE to get the tank in there if anyone has suggestions as to why we would lose vacuum with the tank?
It’s got the TWO ports… in case I didn’t mention.
