What is it? a quiz
Up for guesses, item #3
Cut off end of a heater core pipe?
Another hint…
Cleaned up, but used as a spacer… “manual don’t get it”
Very worn ( out ) idler arm bushing. The one that attaches to the center ( drag ) link ? I’m probably wrong though, as gauging by the coins used for a size reference the ‘mystery’ part looks a bit small.
Automatic transmission linkage bushing?
getting warm…
A homemade brake pedal bushing?
Home made clutch pedal ( support ) bushing ?
Last clue on this one…
The ‘home-made’ piece is an attempt to replicate the automatic transmission ( floor ) shifter bushings - two of them ( in black plastic are shown ).
Bingo! Floor shifter home made bushing(s)
New one for May 20225!
With bonus question: What are they for? Notice anything else?
Zerks for Upper A arm.
Inadequate number of clothes pins. Should be no less than 6.
Proper use of engine ID tag is revealed.
V8… :sunglasses:
Yeah, you really need more like one clothespin per cylinder to see much of an improvement in gas mileage! Lol!
I thought the clothespins were to reduce the possibility of vapor lock…
That could sure be the reason for them - keeps the fuel line spaced away from the hot engine!
Agree with EliminatorClone, some believed the clothes pins on fuel line from pump to carburetor would prevent vapor lock.
A heat sink of sorts…but how different in temperature could the pins possibly be from the surrounding engine compartment?
Don’t forget about “Cow magnets” taped to the fuel line!
