Working on restoring my head light door for my g car and I am missing the round mounting bracket with 3 studs. Dose any one
have pictures of this bracket, diameter of the bracket and what
size the studs are? Cannot find this bracket so I need to make one.
I’ve made several of them in the past. The three studs are #6-32 all thread countersunk screws. The sheet metal circle is .036" steel sheet. I used 4130N material. Two of the holes are existing holes for the deleted standard grille plaque. One hole is added. The diameter needed to pick up the two holes gives you the needed diameter for the part.
The three holes are drilled in the material #27 AWG then dimpled. Three MS21042-06 nuts are used to secure the studs. Then three more of them are used to secure the plate to the grille.
These were originally made by AO Smith with #8-32 thread serts. Edge distance is sketchy drilling a hole that size so I changed the stud size to #6 on the ones I make. Plus I don’t have the tool to install thread serts, it looks sort of like a Pop Rivet gun but is specific to that fastener.
