0F91Q542835
1970 Eliminator
Competition Orange
Black standard Interior
428 SCJ (4.30 gear / super-drag-pak)
4-speed
Ram-Air
This is Denny’s (calypsocoral70) SCJ Eliminator. Sale listing here; http://www.mercurycougar.net/forums/showthread.php?66953-70-Eliminator-quot-Q-quot-code
Other related links; http://www.classiccougarcommunity.com/forum/viewtopic.php?f=10&t=3221
Other Info from the Owner (Denny);
Currently has a non-original engine and C-6 Auto transmission. Solid, strong running daily driver.
I have owned this car for about 18 years and it has been kept in a heated garage.
I put an ‘A’ block 428 punched .030, Lunati cam, windage tray, Holley intake and carb, crane pointless ignition w/rev limiter and Hooker Super Comp’s with extensions to hook to the side pipes. It has a 1ua scj crank.
The trans is a TCI street fighter C6 with a TCI Saturday night converter.
The ram air is long gone as well as the dual horns but the oilcooler, which is hooked to the trans, is there.
Now has a 391 detroit locker.
The odometer shows 39,000 miles and I’m thinking is for real.
No power steering an no power disc brakes.
The interior is black standard with one bad spot on drivers high back, door side lumbar area bottom of the back. The driver door has very small bubbles at bottom corner latch end.
The driver side floor, at seat area, is a little buggered up from what looks like different seat bolt down.
I have put a custom made side stripes, a racing stripe from the hood scoop across the top and trunk and chrome side pipes on it. Clock and tach work. After market steering wheel and floor shifter.
There is a sticker on drivers quarter window stating “class winner” at Connecticut Dragway. Can’t confirm, but with out power robbing stuff it’s possible. I have been told the dragway has been closed for a good while. I also believe that the dealer is gone if I remember right.
The fact that there is no indication it was a 4 speed puzzles me. It’s like the dealer changed it over. The pedals are completely changed, hole plugged, speedo cable changed and the spot where you find the z-bar mount on the frame is as nothing was there. Certainly was not a backyard change over as we might have done in the day.
