1967-1968 Cougar Misc. Parts
1967-1968-1969 Ford Mustang & Mercury Cougar parts from previous projects.
1968-1969 Disc brake conversion includes; spindles, backing plates (not in the best condition), rebuildable calipers, hoses, rotors that measure .915 & .935 spec is .875. Will also throw in rear brake hose and new wheel cylinders and new master cylinder for power brakes. $450.00
1968-1969 Midland band type power brake booster. I do not know the condition so I would consider it a core. $250.00
1968 Cougar fenderwell mounted vacuum canister. $100.00
1967-1968 Power steering control valve in rebuildable condition. $100.00
1968 Mustang & Cougar steering box for PS car in good condition date code 7M6. $150.00
1968 Mustang & Cougar steering box for PS car in rebuildable condition date code 8B1. $100.00
1967-1969 Mustang & Cougar big block reproduction power steering hose bracket. $50.00 have two available
1967-1968 Cougar XR7 fuel sending unit with low fuel warning $125.00
1967-1968 Cougar door courtesy light harnesses in good condition. $50.00
1967-1968 Mustang & Cougar heater box assembly in good restorable condition. $150.00
1967-1968 Cougar front and rear bumper cores $150.00
1967-1968 Mustang & Cougar big block radiator bracket. $50.00
1967-up Mustang & Cougar 390/427/428 water pump rebuilt. $50.00
1967-1968 Mustang & Cougar gas pedal linkage. $50.00 have two available
Non-tinted quarter windows glass only no frame late 67 date code $75.00
1967-1968 Non-tinted back glass late 67 date code $125.00
All prices are best reasonable offer
980-621-8792
Sent you a PM on the fuel sender.
KL, I sent you a PM regarding the FE water pump.
Thanks.
Update parts list:
1968 Cougar fender well mounted vacuum canister. $50.00
1967-1968 Cougar driver quality wheel lip moldings set of 4 Sold
1968 Mustang & Cougar steering box for PS car in rebuildable condition date code 8B1. $50.00
1967-1969 Mustang & Cougar big block reproduction power steering hose bracket. $30.00 have two available
1967-1968 Cougar XR7 fuel sending unit with low fuel warning Sold
1967-1968 Cougar door courtesy light harnesses in good condition. Sold
1967-1968 Mustang & Cougar big block radiator bracket. $40.00
1967-1968 Mustang & Cougar gas pedal linkage. $40.00 have two available
Non-tinted quarter windows glass and vent window glass only no chrome frame late 67 early 68 date codes $100.00
1967-1968 Front window regulators, tracks, lower glass guides $100.00
1967-1968 Door latches, rods, and interior handle pivots cleaned and good condition $50.00
1967-1968 Non-tinted back glass late 67 date code $100.00
1967-1968 Light Blue Sunvisors NEW $25.00
1967-1968 Dual exhaust hangers right and left pair $50.00
1967-1968 Original kick panels dyed parchment minor cracks around screw holes repaired $25.00
1967-1968 Reproduction kick panels dyed aqua NEW 25.00
1967-1968 Front glass weatherstrip NEW Sold
1968-1969 428 Cobra Jet exhaust manifolds Sold
1968-1969 428 Oil Pan with baffle has one repair $100.00
1968 15/16" sway bar brackets no spacers Sold
1968-1969 289 390 428 7AA PS pump pulley $50.00
1969 9" Nodular C4AW case with no N 31-spline Detroit Locker 4.00 8J9 date code Sold
1967-1970 1 NOS Ford spring perch $100.00
980-621-8792
