Not mine,just sharing, seems pricey to me. https://www.hemmings.com/parts/item/19464.html?refer=saturday&utm_source=saturday&utm_medium=email&utm_campaign=2020-06-06
That is a ‘68. They are not interchangeable. Also missing wiper switch
If anybody wants one that looks like that I’d be glad to sell it to you for a lot less.
They are not interchangeable? How is that? Also, how do you tell the difference? I once had a standard 68 and put a standard 67 dash in it. It worked no problem. So, I take it that the standards were the same. Other than minor differences. Just curious about the XR-7 model dashs.
The dash bezel have a different shape in '68 both standard and XR-7.
The tachometer in '67 is different than '68.
The trip odometer button is different in '67 - 68.
The LH turn signal connector is different in 67 - 68.
Wiper switch knob is different 67 - 68.
They can interchange other than the connector for the LH turn signal provided you use the RH side too so the bezels match.
AND…
High beam light changed color.
