1967 1968 XR7 Automatic AC Console Pieces & Parts Black $550
Good pieces and parts for 67-68 XR7 or not… from a collection of bits. Rebuild yours or finish this one. All Black
Descriptions of parts and issues with 49 year old parts! Some are good to go, others may need to go… :slight_smile:
Note: I do not have a wiring harness for this piece nor do I have the front console to dash mounting brackets or mounting screws.
Base; Great condition however someone drilled two 1/2" holes at the very bottom of the base on either side, about where the seat is. So not visible when installed. Not sure why… Already modified for an AC car. Can be modified still for a manual trans. No big giant cracks around screw holes or otherwise.
Top Pad: Looks Very Good Typical separation/shrinkage of vinyl on sides.
Shifter Bezel: Visible chrome is good! What you can’t see has pitting…but you can’t see this when the top cover pad is installed. Typical of an area that is never cleaned!
Clock Pad Face OK condition with some separation from the rear tin. Three posts that hold the clock in place are good.
Clock Works however is off about 2 minutes over a 3 hour test period. Looks nice!
Chrome clock surround This piece has all of the posts on the back side to retain it to the console face. I do not have the sheet metal nuts. It also has the posts to retain the radio trimmed flat and the top chrome bar trimmed out. No tabs for mounting to the dash. Good for installing aftermarket radio? I’m including it because I have it and it is the last one I have…
Ashtray Insert is present, clean one minor chip in the chrome. Lid has minor wear scratching on top, not dinged.
Rear Light Two new bulbs included. Lense is faded but not bad.
Shifter Bezel Black plastic piece has two of the bottom posts trimmed off, no light. No slider bits either.
Will box in new 40-48" 10x10 or 12x12" box for shipping. Will be partially disassembled to fit in box better. Shipping from 95023 for helping you get an estimate. Figure 15lbs weight.
If you need more info please ask! Thanks for looking!
Steve
OK I guess my ability to edit this post goes away at some time…
I have heard no response on this console so am parting it out…
SOOOOO if you just need a part please contact me and we’ll work something out.
Here are the pieces sorta sorted out:
  • Base and light (works! faded plastic)
  • Top pad, chrome shifter bezel, and ash tray, shifter gear indicator
  • Clock pad
  • Chrome Radio Bezel- rear modified for some reason
  • Clock- Works! Slight crack in clear face radiating outwards of center. Lost about 2 minutes over a couple of hours running.
  • Also think I have one LH dash mounting bracket for the top left of console to bottom of dash. No wiring or shifter bits.
Cheers!
Steve
