1967 cougar engine mounts
Hello all, i just discovered i need a driver’s side engine mount replaced.
Im seeing different variations of the mount and not sure which to buy. My 67 has a 302 in it.
Also, i found that i might be able to install it my self. I have done alot of work on this car myself, so hopefully i can tackle the job. Any advice and the correct mount would be extremely helpful.
Thanks in advance,
Carl aka Sunshine, 67 cougar
1967 motor mounts are a thing of the past. They have not been available since around 1972. Normally vendors will substitute the 1968 part which will require the 1968 small block frame stand too. Since your car already has a 1968 only 302 it seems likely someone has already done this. I would buy the 1968 rubber isolator and hope it fits. If it doesn’t you need to buy the 1968 frame stand to make it fit.
Oh boy. This doen not sound fun. Thanks so much.
I really appreciate this information. Im a novice at this and constantly learning.
The issue is most any auto part store will call the 1968 only part 1967 - 1968. If it does not fit you know what to do.
