1967 Styled Steel Wheel
I somehow ended up with this wheel that doesn’t match anything I have. If you need one for your spare or just have to replace one this isn’t bad. I will ship it but that will be expensive. It’s located near Syracuse, NY. I know I’m supposed to price it so let’s say $25 plus the ride.
Hi - are you sure that your wheel is a '67? I need a styled steel wheel for a '68 Cougar and I understand that they are wider and have smaller openings than the '67 wheel (yours looks like it has pretty small openings). Thanks, Dave. Mobile: 905-515-3264.
67 wheels are 14 X 5 1/2. 68 wheels are 14 X 6.
It’s definitely ‘67. The larger openings are apparent when you have them side by side.
You might want to check the radiuses around the openings for cracks too.
I checked it when I took the picture. Good advice though, I know these are prone to cracking that’s why the design changed.
