1968 390 Shift Linkage
What would be the correct factory shifter rods for a 68 with a 390 and 4spd toploader? Thanks Tracy
Would like to help out, but I’m not sure what you’re asking. Do you need to know part numbers? Other vehicles that share the same linkage? Hurst vs. Ford?
What I have is a 68 with the factory shifter but all 3 shift rods look like they have been welded at 1 end of each rod. I’m assuming this was not factory done and would like to possibly replace the rods.
Here is a picture
Top loaders are just beautiful to look at…
That picture is of a 1970 Transmission with a Hurst Shifter. A 68 would be a bit different.
Transmission is the same, only the shifter was changed to protect the innocent ta da
I have a 68 Fairlane shifter, would it be the same rods as a Cougar? If so I can get the numbers of them.
P.S. Currently not for sale…
Fairlane/Torino shifter sits further forward on the tailshaft, so linkage is different.
I’m looking for the numbers that are located on the shift rods for a 68 cougar with 390, 4spd toploader and factory Ford shifter. Do the same rods interchange from small block to big block? Thanks
