Hello! My overhead console warning lights do not come on at all. The bulbs behind them are good … but I can’t seem to identify where the seatbelt relay is or if there’s a fuse hiding somewhere.
The passenger side door is wired in but I am also not seeing a door ajar light. The driver’s side door wiring is physically cut at present so I am not sure if both doors need to be wired in properly to fire off the door ajar light.
Low fuel light has never lit up either despite having a brand new fuel sending unit with the low fuel light wire.
Park light also DOA
Could it be something with the wiring into the starter solenoid? Is there a ‘master’ relay hiding?
This schematic is the only one available - it’s in the 1968 shop manual and also the Wiring Diagram book. It says there is a 7.5 amp fuse plugged into the Yellow accessory wire that has switched 12V from the ignition switch.
I was unable to find that wire or fuse in a 1968 XR-7 I was working on that had the exact problem you describe. I ended up making a wire harness with a 7.5 amp fuse to plug into the Yellow connector and spliced it into wire #365A at the Low Fuel Relay which solved my problems.
