Complete 1969 Cougar 9 inch (Open) (2:75) gears rear end
$550.00
(707) 616- 2310
I forget, any issues if put under a 68?
2 inch rear shoes on the 1969. Wheel cylinder for 2 inch also.
Need shorter drive shaft with 289/302.
I’m dropping in the 351W and 4 spd
1969 manual transmission factory drive shaft might be perfect. If it is from a Cougar.
So I’d need to get a hold of a 69 driveshaft…
In for a penny, in for a pound.
I put a '69 rear axle assembly in a 1968 XR7-G with 302 / C4. I went to a rear end shop and he let me dig through his spare 9" pinion yokes. I found one that was about 2" shorter than the big block yoke that came on the third member. I swapped out the yoke and installed a new seal and nut. The driveshaft length was then correct but the U - joint was the wrong size. I went to the local auto part store where they let me look through their new U - joints and I found one that worked from a 1970 Camaro with 307 / Turbo 350.
