Are the fuse clips missing here?
What’s your application? Standard, XR7, AC? The fuse in the middle of for an accessory block. If you ordered say, a tilt column or speed control, it would receive power through here.
Its standard with A/C. Also the top section that says emerg flasher only has one clip connected to it. Is that suppose to be that why? Thanks
Do we know the recommended fuse amp’age for each of these? I have foil covering mine right now as a temporary fix.
Foil sounds like a fire waiting to happen, get the correct fuses.
Check owners manual or shop manual.
It’s on the chart… if it’s metric foil such as found wrapping cheese , 16 amp…. (This is a metric chart from Australia)
The 1969-73 accessory fuse clip goes in this location.
I keep these kits in stock. Great for adding a switched
connection for power amplifiers, etc.
