1969 mercury cougar xr7
1969 mercury cougar xr7, 351w, FMX Auto with shift kit. Clear title and good tags
Msd distributor and 6A ignition box, edelbrock intake manifold, Holley 670 street avenger carb. Headlight vacuum works and holds vacuum. New ignition switch, new light switch, the tach was redone to work with the msd ignition. All lights and signals work including the sequential turn signals. Interior is all original and needs a little love. Total control products rack and pinion power steering $2300 and full sub frame connectors. American racing rims with Toyo proxes. New master cylinder and rebuilt entire rear brakes. New heater core and it blows HOTT!!! Runs and drives. Needs a new starter, all gauges work as they are supposed too. Needs paint in the future as the clear coat is flaking and some rust bubbling under the vinyl top and its needs a little smoothing on the passenger rear quarter… not bad at all
The obvious question is: How much are you asking for her?
$6500
https://portland.craigslist.org/wsc/cto/6021263134.html
