Hi,
Have a Cougar XR7 1969 HT - with sequential turn signal.
Since the wiring in this car is a total mess and in a really bad condition I am about ot replace it with painless system from American Autowire (AAW) using kit 510177 “1969-70 classic Update kit”. So installation of this kit will need some modifications to fit.
The issue I have is how to adapt the AAW to the existing rear cable wires.
My understanding is:
449 (White with blue stripe) = Right front turn (not sure about this though)
445A (Orange with blue stripe) = Right rear turn
442A (Green with orange stripe) = Left rear turn
511 (Green) = Brake ligth
448 (Green with white stripe) = Left front turn (not sure about this though)
The solid state sequencer controls brake/stop-, park-, Turn signal lamps, the side marker lamps, license plate and the rear lamps.
- it also controls the R/L front turn signal ligths i.e. 448 & 449. I assume these cables runs all the way to the L/R front turn lamps (not sure about this though)
Please correct me if my assumption is wrong!
Since the original rear wiring is in a pretty good shape, I will not replace it but connect the AAW to it under the dash. But I am unsure about these cables 448 and 449 since they are not part of this kit, which is not a surprice.
I think I need to pull new cables to the front L/R turn lamps and skip the routed front turn cables from the kit -the reason is rear and front turn lamps should be synchronized.
Now the question:
How to deal with the 448 & 449 is my thinking correct or is there a better way to do this?
