For Sale: 1969 XR7 Wiring Harness w/ AC & 18-pin Black instrument cluster plug. Harnesses removed from wrecking yard Cougars back in the mid 80’s.
The Dash Harness has a good fuse block, and a good set of firewall plugs w/ resistance wire to tachometer. The ignition plug section of wiring is damaged and will need replaced. A couple of the headlight switch plug wires have been splice/tapped with quick splice connectors. Good for donor parts or restoration. If buyer has interest in using Don Rush’s restoration service for this Dash Harness, I can offer direct transit to WCCC.
Offering at: $100, plus actual shipping cost (no extra packaging fees); USA-48.
Google drive photo link: https://drive.google.com/drive/u/0/folders/19Owk1J3V-RipWvMC0yG6PY7eAi7EYVoh
(Sold) The Engine Compartment Harness has a good fuse block plug. Headlight, horn, parking light, & sidemarker plugs are good. A couple solenoid leads are cut. Offering at: $60, plus actual shipping cost (no extra packaging fees); USA-48. (Sold)
Google drive photo link: https://drive.google.com/drive/u/0/folders/1kWEA9XKXBUVStSBLVlWwL4ctTIYl_SNA
(Sold) The Taillight Harness has the Black & White cowl plugs cut, and a good donor section of each plug with plenty of extra wire is included for splice repair. Taillamp sockets are un-cut and appear to be good. The right rear sidemarker light wiring is cut. Sail panel lamp plug w/ ring ground & Low Fuel plug at tank are present in primary Harness. Offering at: $60, plus actual shipping cost (no extra packaging fees); USA-48. (Sold)
Google drive photo link: https://drive.google.com/drive/u/0/folders/1vkpKHziHiQBrjPHA7wkk9rrTIr03cdHR
I also have other parts available for 1969-70 Cougars.
FMI, Please send a P-M or call / text: 765 - Six, Six, One - Three, Zero, Seven, Eight (Indiana / EDST zone). Thank you.
1969 XR7 Wiring Harness w/ AC & 18-pin Black Plug
