1970 6Z Dark Tobacco XR 7 hardtop interior SOLD
For sale most parts of a 1970 XR7 hardtop Dark Tobacco interior. Vehicle was actually built on 11/15/69 and has been reported to the database and was scrapped in the mid 1970’s. The car was factory equipped with power windows, but an am radio so no speaker holes or have any been added. Parts have been stored inside since.
I do not have the headliner, sail panels, package tray, carpet. I have not found the rim blow wheel, lower dash, plastic A pillar trim or any of the other small parts not listed below as of this point.
I believe most of the dimples, creases etc. will come out and are primarily there from the way the parts were stored/stacked. I have only done an initial clean to get the dust off of the parts.
Brief description of parts follows
Dash pad is flexible and soft, with no cracks even at the speaker grill. It does have some discoloration.
Steering column includes both turn signal and ignition switch, but I have not found the key.
Dark tobacco shift handle is uncracked/blemished with shifter assembly.
Console has one damaged screw hole which I believe will be hidden by the passenger seat otherwise I can not find any damage/cracks. The 3 hump cover has deterioration where the latch would be, but since this is an early build (11/69) there is no latch. The hinge and mounting points are in good condition.
The front door panels are in very good to excellent condition with intact door pulls. The driver’s side has evidence of two screws along the lower front as well as a few tears. The passenger side has one scuff at the rear upper part of panel.
The rear quarter panels are both in excellent condition with no blemishes or damage.
The upper and lower rear seat are both free of damage and the upholstery is flexible.
Both front seat backs are intact, uncreased with tight elastics on the map pockets.
The passenger seat has a scuff on the outer hinge cover as shown in the picture. That is the only damage on the hinge covers, so, it could be swapped with the driver’s inside and would not be seen because of the console.
There are no other visible defects on the passenger seat and again upholstery is soft, flexible and untorn.
The driver’s seat has a hole slightly larger than a quarter located above the seat back release about halfway up. The rest of the upholstery is soft, flexible and untorn.
Both front seats have some wear in the seat bottom foam but it is not disintegrating to dust.
Today I found the 4 lower dash trim pieces (2 @ radio, 2 @ edges), the 2 pieces for the steering column trim (lower piece has a broken tab).
I also have the glove box door assembly and steering wheel pad.
Both floor vent covers each with one small crack and the 2 armrests. Driver side has a crack and swelling.
Pictures have been added to the link.
Price is $2,600 for pickup in Merrimack, NH. I will not box and ship. If you are interested call me at (6o3) 429-8437 and we can discuss potential delivery or a meet on one of my various excursions. I am on the east coast so please call between 9 am and 10 pm eastern time. I do not answer phone calls from blocked or restricted numbers but will return messages. Upcoming known ones are listed below.
Parts that I have listed maybe able to be delivered directly or within a reasonable distance of you to save on shipping costs or for larger or delicate items that I will not ship.
Interior has been sold and delivered.
I found some addtional trim pieces today and updated the above listing and photo link.
Update on pickup / delivery options.
SOLD
