1970 Cougar Eliminator automatic seatback latch system
I am in the process of restoring a 1970 Cougar Eliminator 428cj that i purchased from a guy that took apart almost everything and now I’ve come across a bag with the automatic seatback latch system. The problem is this guy went and had the seats re upholstered. Question 1, Is there a way to install the automatic seatback latch system without having to take the upholstery out of the high back? And if not what are my options.
Never seen the option before…might be pretty rare set up. You should be able to pull the seat back cover off the seat to access most,if not all of where the mechanism goes. Worst case you might have to pull half a dozen or so hog rings on the outside edge of the seat cover behind the seat back cover. Workshop manual should have an exploded view of the set up. Let me know if you need me to look
I have the manuals but does not have the detailed installation. Was hoping to get some insight.
Automatic seat back release was a mid year introduction option in 1970. SBR stamped on the body buck tags if present.
For the original question the diagram of the setup is in volume 4 section 41-02-05 fig 5. You can remove and replace the solenoid through the seat back panel area, but you may have to partially disasemble the upholstery in order to properly route the wiring as well as the release bracket.
Scott, I agree with you on the buck tag, but disagree on the mid year release. The earlist 1970 Eliminator that I am aware of that had it was 0F91G500931 which was built in September of 1969.
I wouldn’t be surprised if you went through your buck tag collection and found similar data.
The build was Dec 6th 1969 Vin is a Q code. Also in the manual does not show the pins with the spring on it. Is all the hardware and the solenoid in the bucket part of the seat, looks like the only thing in the bottom half is electrical which goes under carpet to the dash? Is the front seat back assembly part of the seat?
Dave, I did not know that any had the option that early. Was told that the option was not in the 1970 Mercury Cougar brochure. Been planning on writing an article about my door tag and buck tag collection.
That is a loaded with options Eliminator.
Yes, the Ford employee who ordered it, didn’t miss too many boxes. The strange one is AC was ordered but without tinted glass. The other options I think he missed are a Console, Interval Wipers and the Appearance Protection Group.
Auto seat back release actually is listed as an option in the 70 Cougar brochure. I didn’t think it was either, but here it is under Interior Options. Maybe I have a later printing of the brochure?
Interesting that Mercury would make this option available in 1970. They had a experimental setup in 1967 on one of the existing cars. Maybe it took a long time for the parts to be available.
Is it located in the upper part of the seat or the lower? Before i start taking it apart.
Upper, on the latch release side. The components are all in the seat back portion. There are no affected components in the seat bottom portion.
