I am currently restoring a 1970 Cougar Eliminator 428cj with ram air. And am looking for paint colors and who sells what for all of the different areas of the car. Engine bay, hood hinges, hood latch, under dash, under carriage, interior, interior fire wall. The Car is Comp Blue hoping someone has done a restoration with concourse in mind but doing the restoration myself. Trying to get close.
You should check out the concoursmustang.com forum.
Lots of tips, techniques, and explanations. Each component and subassembly should be considered individually. Don’t go crazy with the sandblasting every part. Some items should not be sand or bead blasted. Vapor blasting is a thing. Cast iron parts should be ‘natural’, Eastwood cast grey paint will not give great results.
Marcus Anghel has a very helpful website and great articles. Everything that applies to a Mustang can be used on a Cougar. Magazine Articles | Mustang Feature by Anghel Restorations
Using paint on originally non-painted items is generally referred to as a ‘rattle can restoration’. You have an investment grade car, and you should consider the end result.
Do what you want, but do consider the end results which ever way you go.
That’s why I’m asking for help with the paint colors. Their has to be someone who has all this information. I cant be the 1st one to restore a 1970 Cougar
There’s not any one source that explains everything. This is a learned process.
Thanks
Anghel also has a number of other restoration guides…i.e. suspension.
Wow, there’s a lot of information in that mustang factoid article. Thanks for passing putting it out.
As previously mentioned, there is no “master list” for restoration details. However, the Concours Mustang forum has almost everything you are asking for.
1970 Dearborn Undercarriage
70 Dearborn Undercarriage 8-2017v3
Factory Sound Deadener and Seam Sealer
Article - Sound Dead - Sludge.pdf
General info on Paint Markings
Publication1
Slop Gray for 1970 body parts (this includes info on phosphate & oil and semi-gloss black in the engine bay, as well as other details such as the hood latch).
Article-69-70SlopGray
Here is a collection of pictures from unrestored 1970 Mustangs. Lots of good reference pictures to be found.
70 Mustang & Boss
Hood Hinges
hood_hinges_v1.1.pdf
Interior Firewall Discussion
70 Dearborn - Firewall Insulation
So, the Councours forum has what you are looking for, but you’re going to have to dig a bit to find it. Also, if you can’t find it, you can post what you’re looking for and someone there (or here!) almost certainly has the answer.
