Just pop the cover plate off the base of the antenna and remove the 4 screws. Then you can just lay the antenna down on the body, after you lay down a towel or some other type of cloth to protect the paint of course. The cable has enough slack in it to do it that way.
Newbee here as well.
I went with the Cal Cover option as well. Say a descent advertisment in Hagerty. It’ll be in here in a few weeks and like you, indoor storage is the dealo.
I got this one: Satin Fleece Stretch Fit Indoor Custom Car Cover with Fleece Lining (SKU 69F3).
Best - Will
So another question, anyone with a dustop cover, which side of the seam does the antenna hole go on? It pretty much falls right in the top/side seam. So is it better on the top side of the seam or the “side” side of the seam??
Mine is just below the seam.
Steve
