1970 intermittent wipers only working on low speed
I turned the wipers on and discovered I only have low now. I also don’t have the wash function.
It’s possible I did something silly or have a bad switch. I did remove the dash to repaint the lower, but didn’t unplug the switch. Car has original intermittent wipers, but the delay doesn’t work either.
I looked at the schematics and before I dive into it I’m wondering if the symptoms are indicative of an easily solved issue (like the ground needing to be cleaned, the switch being bad, etc.).
Thanks.
Im not 100% on this, but I recall an issue b4 and it was the motor. See if you can plug another one in to test your system.
When I talked to the original owner of m 70 XR-7, he said he had to do something in the box. I think it was adding a ground. If the simple things like checking the motor and grounds doesn’t work, I’d look for a T.S.B. on it. and or find someone who is good with older electronics.
Switch must be grounded to dash to work correctly on all positions. And there are alot of moving parts in that switch to fail. The shop manual has a table you can use to check out the switch.
I fiddled around with it some more. It does the delay and low, so it’s just missing high speed.
I appreciate the responses. I’m going to clean the grounds and see what happens, then go from there.
Removed the switch and found the ground wire in tatters. The old riveted wire terminal was in pretty poor condition, so I drilled it out and replaced it with a new terminal, riveted on, and a new wire.
Still no high speed, but it needs that ground no matter what. So, I looked at the motor ground and found it was the world’s okayest ground. Fixed that, and still no high speed.
So, I guess I’ll test the motor now since I suspect it’s dying or the magnets have weakened over the years.
The switch gets grounded to the dash directly when mounted, so the wire is just extra assurance. While removed, verify the switch is good using the table in my earlier post before you tear into the motor.
I used your very helpful share of the diagnostic procedure. Couldn’t get it to do anything where the resistance value was, but it looks like that’s for the delay portion. So, I sort of figured I was holding my mouth wrong since the delay and low work but High does not.
Couldn’t get anything but OPEN on my meter.
That might mean the switch is deader than disco. IDK.
You are right, the resistance test is for intermittent and you should see it vary as you turn the knob. Mine was open and unrepairable. Found a NOS switch on eBay. Anyway, if those terminals truly were open your intermittent wipers would never go.
Sounds like your meter might be deader than disco (love that analogy!). Meter battery ok?
The meter seems okay, but I probably do need to swap the battery for a fresh one.
Looks like replacement switches are thin in number now. I’ll keep my eyes peeled for a spare, but I’m probably just going to rain-x the windshield and keep moving forward getting ready for power tour.
Looking at the schematic, it appears I can feed 12v to the high speed circuit through the switch plug and test the motor from inside the car. Once I can establish the motor is good I can safely conclude it’s the switch. Or, I’m wrong about testing it and will find out.
Was it the motor?
Yes and no.
It’s possible the motor and switch are bad. I decided to drive it a bit and see how it does, if it limbers up and works again after not being used in the rain for a while. Still only have low, but it was intermittently stopping altogether and then starting again.
I need to do a full test again and see what I see.
Further testing showed it still only works on low, but now I’m having an intermittent stoppage that lasts for maybe 15 seconds and then restarts. Got caught in the rain a couple of weeks ago and the wipers kept stopping, but mostly worked (98 percent) on low.
I’m up to do some more diagnostics. I’m not sure it’s going to limber up and work, so I may install the new solid state delay box and switch.
I’m not sure why you won’t change the motor…
I have several extras
It’s not that I won’t. I’m just trying to make sure it’s the motor before I go changing stuff, but the system hasn’t been used in the rain for a long time. So, I thought I’d give it the chance to limber up and work.
As an example, my blower fan began working on that trip, just out of nowhere.
Intermittent electrical problems are more likely to get worse than fix themselves over time. You’ll probably end up having to troubleshoot and fix them. Having said that, my heater blower also suddenly started working out of the blue. But I know it’s probably still got a bearing problem that I will have to address someday. Keeps us out of trouble at least!
Turned out to be at least the motor. But I still need to find a test protocol for the intermittent box. Also need to test the switch.
I expect I have some poor grounds on the dash harness, or dirty ones, so my procedure is 1. Clean grounds,
2. Test Intermittent Wiper Box
3. Test Intermittent Wiper Switch
Just to see if anything else is wrong. I spent a lot of time summer and spring riding around in the car and doing motorcycle stuff, so now that it’s winter I’m back doing the interior stuff and getting the A/C system back online.
Yep, got that one… Motor!
Everything else is now testing okay since I bought a good meter. Pretty happy I get to keep my original delay box and switch.
I tried disassembling the original motor and cleaning the brush surface, looking for busted solder joints, etc. but to no avail.
Anyhow I have a new one on the way. We’ll see how that goes. I have 30% less faith in new parts working than I did 4 years ago.
Anyway, that’s some nice progress.
Looks like I’m back to square one. Wipers quit on me again.
I pulled the motor and now have one of those “no, really, it fits” fox body motors, a spare used motor, and the original. So, I’m going to go through the whole system and see what’s up with it while it’s pouring rain and I have the car apart to fix a windshield leak.
