Hi,
1971 cougar xr7, water temp ?
- pulled a 192 degree 2bl, thermostat.
- temp needle runs almost pegged towards the hot.
- shouldn’t the needle be more towards the middle ?
- what does the gauge represent from cold to hot in temperature readings ?
confused between 180 or 192 thermostat for the 351 Cleveland motor and the restrictor plate is there.
I plan on putting in a Stant model # 13468 ?
thanks,
philip
All the different rated thermostats do is decide when it will open. This is what you need, works every time!
https://secure.cougarpartscatalog.com/waterrestrictplate.html?attribs=79
hi,
how do you remove the old one ?
will this lower the temp gauge reading ?
what does the smaller hole accomplish ?
thanks,
philip
Just read the reviews on on our site and click onto the links. To remove the original brass plate you pry it out or use a slide hammer.
hi don,
-always had a squeak in the front left area, finally figured it out to be the following.
-driver side shock tower, can’t get one carriage bolt into slot, so it doesn’t turn.
-the upper part where the coil sits into, is that welded to the car ?
or
-can i take tension of the spring and rotate that piece, and what is it called ?
thanks,
philip
