Im working on a 73. And when the ignition key is in the acc. position the blinkers work! But when the key is in the run position they do not? Ive changed the ignition switch and they work they same? any ideas??
Sounds like your loosing power somewhere if they work in accessory position.
See if the below helps your voltage checks ![]()
check the steering column harness
