Having tried a lot of carbs, I have some strong preferences. If you can spend the money, some of the high end Holley type carbs have nice air bleeds and a lot of tuneability.
To put this in perspective a bit, the Dominator carb (at I think 750CFM originally?) was designed for the Boss 302. And you can even make them streetable. But that’s not a cheap carb or intake!
For street, the old Autolite 4100s and Summit carbs are mighty hard to beat. I’ve tried AVS/2 as well, and while it’s better than the usual Carter knockoffs, they’re not as easy to tune as the M2008VS is by a longshot, as well as being more expensive.
If you already have an AOD, well, good on you; overdrive and some higher numeric rear gears are always fun! But the AOD has a lot of shortcomings. Its two piece input shaft will either bind or shear on full throttle 2-3 and 3-4 shifts. The stock shift quality is as as weak and slow as your average politician, which doesn’t endear this transmission to me either. All of its shortcomings can be overcome with the application of very large amounts of money, but often eliminates the torque converter lockup feature.
If you want overdrive, and don’t mind changing your rear gears, IMHO the 4R70W is a much better choice. It has lower 1st and 2nd gears, vastly improved reliability and shift quality, and you can easily tune how it shifts.
Most of my friends with AODs spent over 2500 on the transmission alone.
My 4R70W cost me less than $500 total if I recall correctly (including some mods to make it shift harder and handle 400+ horsepower). Even if you add the cost of a transmission controller (It requires one), that’s only another $400-600. Since I needed a computer for my 8 stack EFI, I just went to the Terminator X Max, which has a transmission controller included anyway.
In the end, spending less and getting more is a big win in my book. The two transmissions are closely related, but the newer 4R70W has a lot of advantages, including lower total cost of ownership. Get one from a '98-01 V6 Mustang for cheap, and it will be in great shape even if the car was high mileage. My own showed virtually no wear at all, and had never been opened.
I do feel I would be remiss in adding that the 2100 is NOT a bad carb, though. You may have had some leaks, but this is likely a result of ethanol in the gas you’re running, and outdated internals that weren’t intended for it. It tends to eat the accelerator pump and power valves. If you overtighten the covers to “stop the leak”, that creates more problems and makes them leak more. The 2100 is actually a fantastic carb. The 4100, its big brother (and the Summit carb) are superior in terms of peak performance, and even economy if you can keep your foot out of it, but the manifold itself is going to be a significant improvement in power as well.
With modern fuel, all carbs tend to have more problems than EFI, especially if you drive them and then leave them to sit for a week or more. The fuel will separate as the alcohol absorbs moisture from the air, and then chemical interactions between the water, fuel, additives, and carb metals will create crystals and corrosion.
Lastly, do not worry about whether these carbs are “compatible” with AOD, even if you go that route. It is 100% a nonissue. If you have any mechanical ability whatsoever, you can figure out how to hook up a TV cable, and create a way to connect that cable to the throttle to ensure that it works properly. It is not very complicated. =)
