1973 XR7 Vert, sequential turns work fine but emergency / 4way flashers dont flash, just stay illuminated front and back lights. Any suggestions?
Does the '73 use separate flasher can for e-lights from blinkers? I’m pretty sure 69 does. That’s what I’d check first.
Or… read the Cougars Unlimited Troubleshooting guide
Go to Vic Yarberry’s web site for troubleshooting tips and parts if you need them.
He has the troubleshooting for '69-73 as the same.
But by the sounds of it, it is the separate emergency flasher can.
yep, separate can. its in your glove box.
Thanks, i’ll check tonight. I had done some searching and thought that was the direction to go but figured I would get some experienced direction from the members.
And the nice thing is, the hazard flasher is just a standard can, available at any parts store, not a special part like the turn signal flasher can.
