I recently picked up a 67 base edition cougar that was more rust than paint. I’m about 20% into the rust removal/prevention, undercoating, and painting. I am going to be building a high-compression engine to run only E85 Ethanol at a CR of roughly 13.0-13.6 : 1 which will also mean not being able to run pump gas in a pinch, to burn Ethanol more efficiently. At first I thought about building a 351W since it made sense for the car. Then I decided to go Cleveland instead because I’d just end up building the Windsor into a Cleveland. Finally I decided I would build a Ford 400, for several reasons.
Firstly, to raise the CR easily, my first move with a 351C would be to stroke it no more than a square bore/stroke, to 400. Of course, for that means, the 400 block would just be a stronger, higher-decked, and stroked Cleveland. Not to mention I’ve built them before and 500hp with 600 ft/lbs is not hard to achieve. I do not have a HP goal, though, because as I said earlier that’s not quite the point. While adding H/C aluminum heads, H/C pistons, hi lift cam and the rest of the bells and whistles that will be necessary to achieve the high CR will be a great recipe for more HP and Torque, the main goal is to burn Ethanol efficiently.
Although I am expecting to build a lot of power with this build, and doing so with a slightly heavier powertrain (though I believe lighter than a 390?), thusly I will need to strengthen the chassis and unitized body to take high torque. And I’m going to at least need disc front brakes.
Obviously I have multiple questions about different projects to come.
One hurdle I’m certain anyone reading this is contemplating is the method of squeezing a 400 between the shock towers of a 67. And I’m very open to all the ideas I can get. I can see from searching that it’s been done at least twice, but not very well documented as far as I can find. One of the more promising fixes I found would be the AJE Racing Mustang Tubular K-Member MU-90UM, and then fitting the motor mounts. I was wondering if anyone had any experience with that K-Member, or a similar one that works better.
I’m also planning on adding a monte carlo bar, along with shock tower braces, and subframe connectors. I was hoping someone would want to tell me about the Heidts RM-023 Chassis Stiffener and if there was better. One question I have is since I’m adding all this structural reinforcement, should I/do I still need to weld in a passenger side torque box?
A far as the rear end goes, I plan to be swapping the 8" for a 9" and while I don’t feel the need for an expensive 4-link setup, I would like to add (aside from an obvious anti-roll bar) a panhard bar. However, I have not managed to find any weld-on or bolt-on kits for cougars or mustangs. Am I going to have to fabricate this myself?
Another question I have is which front end kit to go with. I’m certain this is a very common discussion, but I’m not looking for a road-coarse car, I’m more interested in the suspension kit coming with good springs and disc brakes. So I’m not looking for the cheapest, I’m just looking for an affordable one that might not be the best handling, but comes with disc brakes.
Lastly, I have not been able to locate a replacement floor panel patch for the driver side section under the rear seat, behind and above the rear footwell. I’ve considered patching it with flat sheetmetal since it’ll never be seen under the rear seat, but I prefer not to half-ass things when given the opportunity.
I think that’s all the questions I’m bouncing around right now. Oh yeah I’d like to find a fiberglass hood, but everywhere I look says nope. The 400 block and crank are at the machine shop, and the windows and bumpers are up in the attic until the end when I need them.
Thanks for reading, here’s some pictures.
