This is a 1967 stamped steel wheel that is 14" x 6" with a 4 1/2" bolt pattern and a 2 3/4" center hole. The date code is 7ME (the 7 is upsidedown). That is 1967, Motor Wheel Corp, May. It is riveted in the center showing that it is an early Ford rim. Blasted and powder coated. I would rate this a 8-8.5 out of 10 due to some pitting showing after the powder coating. Asking $150. Will work with shipping based on where you are located.
