New to the forum, likely know a lot of members, been an FE guy on all the forums for a long while.
I recently came into a 7F dated 68 hyd cammed 427 block, .040 over, that is ready for assembly. The original owner of the engine got way upside down with another builder and then didn’t trust the assembly. I took it in and after finding issues with the heads, intake, rockers, and a long list of mismatched bolt ons, instead of finishing the engine after I did all the blueprinting for it, he washed his hands of it. It had an old school rotating assembly that I sold (SCJ rods, CJ crank, and a set of Venolia pop-ups) but I was finished with the short block measurements and balancing and was ready for final assembly when he decided he was done.
Little to no measurable taper, clean and nice, sonic checked good, a couple of cylinders have a light skirt scuff due to the last builder not beveling the bottom of the bores. My recommendation would be to buy pistons to match the bore and assemble as either a stroker or a stock rotating assembly.
Here is a link to all of the pictures so you can look at all the cylinders (I didn’t want to go crazy on linking pics and make it slow to load)
https://postimg.cc/gallery/wHtd7R8
And here are some key initial pictures, note cross bolts and spacers are there, I just have them off to the side while I was documenting the build. Has new ARP bolts and was align honed.
Measurements
Deck height
1 10.149
4 10.150
5 10.148
8 10.151
Cyl 4.268+ Bottom Top Taper Bore size
1 0.0087 0.0087 0.0000 4.2767
2 0.0080 0.0080 0.0000 4.2760
3 0.0085 0.0090 0.0005 4.2770
4 0.0082 0.0082 0.0000 4.2762
5 0.0082 0.0082 0.0000 4.2762
6 0.0082 0.0082 0.0000 4.2762
7 0.0080 0.0085 0.0005 4.2765
8 0.0085 0.0085 0.0000 4.2765
Happy to get any other information you want, as I said, this was going to be a build and I have all the information available… Looking for 3500 plus shipping from Omaha, bare block only, First picture was as it came in for blueprinting, the rest I took for someone else interested. Numbers on the bottom are current bore sizes
