Hi, everyone,
I’m brand new to the forum and this is my first post. I purchased my 68 Mercury Cougar back in February after a couple years of reading, researching and learning about the car. Its got a J-code 302, automatic and A/C. The paint and body are in really good shape, and mechanically it has just enough things that need work to make it interesting.
I had a noticeable shimmy in the steering wheel while braking, so assuming the front drums were at fault I set about purchasing and installing new shoes, hardware and drums (the old ones were out of spec and could not be resurfaced). I haven’t worked on drums in years so I of course read my repair manual and checked out some good online tutorials on drum replacement. Overall installation was fairly straightforward and I had no issues. I cleaned up and lightly dabbed caliper grease on the back plates before installation of the new shoes and I verified the shorter shoe is installed on the fronts of the backing plates. The wheel cylinders were not leaking and the rubber boots were in nice shape so I did not change them. I also cleaned up the spindles, hub assemblies, and inner and outer wheel bearings (installed new inner seals) and repacked everything with grease. I adjusted each drum until there was some slight drag when I spun the wheels by hand. I sprayed the insides of the new drums with brake cleaner to help remove the light oil coating on them and sprayed the surfaces of the new shoes to remove any greasy fingerprints I left during the installation process. The outer bearings were installed and seated and I torqued the nut on the spindle to spec according to procedure. I put my front wheels on and torqued the lug nuts to 80 ft-lbs.
Well, the shimmy in the steering wheel is gone, but it’s been replaced by a severe shuddering that I can both feel and see in the steering wheel & column (shudders up and down) and I can feel it in the pedal any time I apply the brakes. I can notice it at any speed above 25 mph when hitting the brakes, but seems worse when I brake from higher speeds.
I took off the drums this morning to double-check my work. Nothing looked amiss, but I went ahead and re-assembled the shoes and drums, and re-sprayed both with brake parts cleaner and wiped out the insides of the drums. I re-installed everything, put on my wheels, adjusted the shoes until there was some drag on the drums, set the car down on the ground and re-torqued the lug nuts. No change - I still have the bad shuddering while braking.
Does anyone have any suggestions of things I should check, or perhaps any steps I missed in the process that might cause such a bad shuddering? I’m puzzled and out of ideas, except for the idea of replacing the drums with discs, which I’m not quite ready to do yet.
Thank you!
