68 Cruise Control Switch
I’m looking for the on/off switch for the cruise control on a 68 XR7. Not the turn signal push button switch, I have that, but the switch that mounts under the dash below the ignition key that you pull to turn on the cruise control. It has a tiny red light in it that looks like an LED except it was made a couple decades too early to be one. If anyone has one, or knows the part number I’d appreciate it.
Thanks,! :slight_smile:
There’s been a guy on eBay trying to sell one.
I’ve been monitoring eBay and haven’t seen any. Do you have a link?
Thanks,
Sorry I don’t. I tend to blow right by it since I don’t need one.
I have exactly what you need. call me 248 867-3522 Ray Bischoff
What’s a good time to call? My Murphy’s Law luck has been that I get no answer when I call you. If you see a 303 area code call, it’s probably me.
Thanks,
Mark Kraffert
(303) 325-6883
Speed control parts are now worth more than gold ounce for ounce!
https://www.ebay.com/itm/rare-nos-1967-1968-1969-mustang-speed-control-turn-signal-lever-D1VY-13305-A-/293061694303?epid=753963889&hash=item443bd6935f%3Ag%3AEIYAAOSwcwdcv2Ya&nma=true&si=d08gphLWKCWi07dlFhkdEP4QGLU%253D&orig_cvip=true&nordt=true&rt=nc&_trksid=p2047675.l2557
I’m the guy on eBay with the switch. I am working on installing Speed Control on my 67 Mustang and I picked up a complete Cougar system back in the 90s. I have also been collecting Speed Control parts for over 30 years until I found the ‘perfect car’. Now that I have the car, I’m selling off the parts I don’t need.
I’m the_cat_reaper on eBay.
I can use the servo (bellows) unit, but really, that’s about it. I have the control head (without bracket), wiring (sold), turn signal and knob on eBay. I also have a few spare bellows that I’m selling along with a mixed lot of misc Lincoln and T-bird hardware. I am hanging on to the speedo cables just in case I need them.
I agree, they are expensive, but I’m facing something even more ridiculous–I have an early model 67, so I have to use the Curtis Wright system. Talk about expensive!!!
I have everything I need for the 67 CW system except… you guessed it, the bracket that holds the control unit to the firewall. I should be able to make one, but I would like to have an original or be able to make a template from an original.
I would be wiling to trade any of my 68 parts for 67 parts!
You are in the murky area of early Cougar/Mustang speed control. The G prototype mule given to AO Smith was a 67 that has the CW unit attached between the shock tower supports. I had a member of one of my Ford clubs who had a 67 Mustang built early Sept 66 with the CW also. Then you see Cougar 1 that has to be the earliest and it has the Perfect Circle servo and newer turn signal stalk??? I’ve never been able to find a good explanation why and when the CW was used. It was used on early 67 Thunderbird/Lincoln also. Hang on to cables from the trans because it has a slightly larger diameter driven wire that the servo requires.
I have this speed control part for sale on eBay. I got with the cruise components for my 1969, and obviously it is not applicable. It is rare and limited to the early production ( Curtiss-Wright ). It wasn’t used on the later ( Dana ) Perfect Circle version. Not sure if it was also used on the T-BIrds and Lincolns of that period. eBay listing # : 273 899 188 170
The above solenoid (valve) mounts to the top of the Curtiss-Wright servo unit. Usually when you can find a used unit like this the hose nipples are broke off.
