This is my first post and intended to be both my introduction to the group and first HELP! call. I’m looking forward to being an active member of the group.
I’m a long-time owner and and even longer-time enthusiast. My first “Cougar experience” was as a teen in the late 70’s when the fam owned a '68 XR7 4-speed. Oh, how I wish I still had that (NJ) rust bucket.
Cat stats are in my signature, below. This is an AZ car, about as close to stock and rust-free as any out there. I’m the third owner and used it as a daily driver from 87 through 94. In early 96, I drove it to OH, where it remained – garaged, awaiting restoration – until mid 09. The resto never happened so I trailered it back to AZ in 09. Now, in 15, mileage is 142,817 and I want to get it back on the road, at least short term as a daily driver. My goal is a complete stock restoration in time for its 50th birthday, July 20, 2018!
For now, though, I’m just trying to get it going again. I began by removing and cleaning the fuel tank, rebuilding the sending unit (the float was missing, except for a flimsy narrow brass ring where it clipped into the arm), flushing the fuel lines, replacing the fuel hoses and filter, and adding a pre-pump filter (for good measure). It started, briefly, two weeks ago: ran OK for a few minutes and then began stalling. Turns out the fuel pump was irrigating everything but the carburetor. Now it’s up on stands, sans wheels.
Years ago I rebuilt the front suspension, new clutch, new brakes, and basic general maintenance. All that work paid off: I increased the MPG from 11.7 to 17.3 over about 18 months. Except for the manual drum brakes, that’s all still in OK shape. I’m in the midst of replacing all four wheel cylinders and flushing the lines. It may need a new master cylinder, too.
When I moved the car in 09, I had to make a temporary repair to the clutch equalizer bar. This morning I was preparing to make the permanent fix and install a new firewall boot, so I removed the upper clutch rod. Turns out it wasn’t even secured to the clutch pedal arm because the end of the rod was 1/2 worn away. I checked WCCC for a replacement, but what they offer [http://www2.cougarpartscatalog.com/6770bbupclutchrod.html] is different from what was in the car, which looks exactly like what is shown as Equalizer Rod 7A156 Fig 3, p5-12 of the '68 Shop Manual: a shallow “U” shape, 12-1/2" long center to center each end. (I’d attach a photo but it keeps telling me that my image is 60 pixels too wide, and resizing it doesn’t seem to help.)
My first questions (of many, I’m sure) for everyone here are:
Is my worn clutch rod likely original?
If it is original, why is it different from what everyone is selling for this model year?
Thoughts / Recommendations on where to purchase a replacement? I’ll need end bushings, too.
Thanks.
