Can I install a 68 collapsible steering column in a 67? Will the 68 upper column mount fit in a 67?
Thanks in advance,
Mike Tuck
Thanks in advance,
Mike Tuck
It all bolts in. You have to use the '68 column mounts and change the electrical connector to '68 style.
You’ll need a steering wheel designed for a ‘68. The ‘67 wheel won’t fit.
Well that sucks…don’t like the 68 steering wheel. Maybe go aftermarket with the GT Performance Steering wheel.
Thanks
Mike
So if I get the 68 column to dash bracket it will bolt into the 67?
That and the plastic connector shell for the turn signal / emergency flasher / horn wiring.
Thanks in advance,
Mike TuckSo if I get the 68 column to dash bracket it will bolt into the 67?
Perfect…thanks for the help!
The 67 wheel will fit. It will have a space between the base of the wheel & the column. I put a 68 tilt in the wife’s 67. Used a plastic cover from a can of peanuts as a bezel… Someone here did this & showed how… just don’t know where the thread is…
