Thanks Bill Gotta work this weekend so I’ll give it a try when I get a chance and let you know. Truly appreciate your support
That’s the correct way to do it
What color wire at the ignition switch does the red igniter wire tie into? I tried this. It appears the tack is bumping around as I turn it over, but it will not start.
Kind of late in the day but I think I see a wiring scenario under there I have not tried ; I did not have power running through the tack. Let me recheck one day this weekend and I will get back to you. Thanks again.
Red with green stripe - it runs from ignition switch to tach plug. Your red ignitor wire splices into this AND it needs to ALSO plug into the tach like it was wired from the factory.
Then the other tach wire is the pink resistor wire that heads out through the firewall to the coil + through the engine harness.
OK update guys apparently I never did cut the resistor wire. I tied the igniter into the red with green stripe as directed(luckily) : and red wire with green stripe tied into tack, other side of tack, tied into resistor wire: it still did not start so I retraced everything : apparently in the engine bay I had the red wire with green stripe(coil wire) tied into temperature sending unit. ; red wire with white stripe(temperature sending unit wire) tied into the Coil ; yes, I feel very stupid but switched wires around. Car starts tachometer works great thank you all for your help.
Separate question Calicat on the backside of the ignition switch the red wire with the white stripe. Where does it go? I noticed mine does not seem to be connected to anything.
Well done! I don’t see a red-white wire listed out of the ignition switch.
That is for a proof-out oil pressure indicator lamp, which you probably don’t have. These wires are almost always found on replacement ignition switches, which are used on many models, some of which have oil lamps and others do not. You can disregard that wire.
Ok thanks got it just disregard
Thanks to everyone for all the help
Hoping to be driving within the next month or so
