68 XR7 Restomod ideas appreciated
I’m in the middle of updating the 68 XR7. So far
  • add dual 12" fans, one wired to come on with the a/c and both wired to come on with temp hits 90C
  • 130 amp alternator
  • Sanden a/c compressor
  • a/c on/off switch - a/c works on any setting
  • electric washers, operated from foot pedal, using a 69 washer bottle
  • larger a/c condensor, requiring dryer to be relocated
  • upgraded the lights to more powerful QH
  • relay pack for fans, a/c compressor, horn, washers
  • fuse box for all of the above
  • fog light relay for later additionof xr7-G front pan
  • RCCI relays and headlight door drivers
  • Electric headlight doors
The wiring has been run into the cabin and I need some advice on where to mount the following
  • a/c on off swith
  • engine fan on/off switch
  • engine fan on indicator
  • fog lamp on/off switch
  • fog lamp on indicator
  • rear demist on/off switch
  • rear demist on indicator
  • trunk remote push button
I’m using separate indicator lights as I am switching the ground on the relays to provide power to the particular component and switches with LED indicators don’t like the power running that way - they like the positive switched not the negative
Any ideas on where the switches / indicators could be mounted.
Leon if you are not using the ashtray you could fabricate a panel to mount most if not all of your switches. This panel would be concealed when the ashtray door is closed keeping a stock appearance. Just a thought.
Leon, will this car have a console?
Is it getting a RHD conversion, or does it already have one?
What is a rear demist?
scott
Yes it has a console - XR7
Already RHD
Rear demist = rear screen heater
I was going to move the heater controls to the ashtray area but putting them on a panel behind the door is a neat solution
My only thought is to mount the trunk remote away from the other switches in a hard to reach place so you don’t hit it accidently.
I hide a lot of stuff like you’re describing inthe glove compartment. However, it does sometimes render the glovebox useless. It’s the “price of coolness” I supposed." Obviously I support the re-use of the ashtray area. :thumbup: but using a compartment in the console is a great idea as well.
I don’t want to hijack the thread. It is that air ride controls in the glovebox Mark? Cool!
You are correct sir. No worries, though, it could also be a 68 RestoMod idea. :poke:
