Hi everyone
Thanks for taking the time to check out this post, and for any help you can provide.
I have a ‘68 XR7 over here in England. I’ve had some intermittent issues when trying to start the car. She cranks fine, fuel is getting into the 4 barrel carb with no problems. She just won’t fire up.
Just for reference, she has fired up in the past and drives beautifully, however, I kept running into an issue where I would take her out for a drive and if I stopped at a gas station, for example, when I went to start the car again she wouldn’t start and I would have to jump her (this was with an old battery which has since been replaced).
I’ve been doing some research on the wiring of 68 Cougars, as well as the XR7, so I now know about the issues regarding the tach issue with XR7s (mine has not worked since I got her). This got me wondering when I saw this main harness in the engine bay: what am I looking at here? Why has the red/green wire been cut? The red/green wire that’s been cut at the 2 pin connector has been connected to another wire and I’m not sure if that is the pink resistance wire.
Any help and/or thoughts on this would be greatly appreciated.
